Loki 2.4.1 does not start with ingester_config or compactor_config
I’m running Loki 2.4.1 (latest), official docker image. It appears that I cannot use the ingester_config or the compactor_config fields. When I do, loki fails to start, and spits out the following log messages:
line 9: field ingester_config not found in type loki.ConfigWrapper
line 41: field compactor_config not found in type loki.ConfigWrapper
The relevant configuration that I use is
ingester_config:
  chunk_idle_period: 15m
compactor_config:
  retention_enabled: true
Are these configuration fields only available in a later (non stable) version of Loki, or do I need to make additional settings to make it work?
And figured it out myself:
Although these blocks are called compactor_config and ingester_config, they must be simply called compactor and ingester. Inconsistent documentation ?
ingester:
compactor:
