ans: Grafana version 10.4.1 and ubuntu OS -
Logs: Infinite scroll in the logs visualization · Issue #71728 · grafana/grafana · GitHub
in that link you said : infinite scrolling is available in Explore, Explore Logs, and Dashboards. For dashboard users, remember it’s an opt-in feature in the panel options:
but in my panel edit section is not present : -
ans : if scrolling option was there, it would solve my issue -
What happened?
ans: infinite scrolling option is not showing in my panel edit section -
ans: The infinite scrolling option should show -
Welcome @mdarifmanihar123
Maybe that feature is available in a newer version of grafana?
