I’m having a strange issue where logs are dissapearing almost immediately after injest. I believe it’s related to the timestamp of the logs. I am using Logstash to parse my logs and send them to loki. If I add the Date filter to change the @timestamp field to one present in the logs, they get deleted from Loki almost immediately. When I injest the logs and refresh Grafana, I can see the various labels getting detected, but by the time I select a label and search for it, there are no results found. Within 30-60 seconds of inesting the logs, the labels dissapear from Loki as well.
Here is an example log line:
INX00086E1637,10304612822043760453|1654009231.8297705715,2,2022:05:31:15:00:31:849,2022:05:31:15:00:31:850
I am using the date filter in Logstash to set the @timestamp field to the 2022:05:31:15:00:31:849 field in the log file. I have verified this is being done by Logstash correctly by setting a test field to the same value. The field shows the timestamp being converted to 2022-05-31T15:00:31.849Z
If I comment out the Date filter the logs are ingested and displayed correctly with timestamp field set to the ingest time.
Here is the filter snippet of my logstash config file (note the “timein” field corresponds to the timestamp referenced above):
date {
match => "timein", "yyyy:MM:dd:HH:mm:ss:SSS"]
and my loki config:
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
limits_config:
max_streams_per_user: 0
max_global_streams_per_user: 0
max_query_length: 0
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
Has anyone seen this before or have any ideas what might be causing this?
Thank you!
