Load5m / cpu core
'm trying to get a the result of the max_over_time load5m divided by the number of CPU cores I have a table with the below queries and both works
query D = max_over_time(node_load5{job=~"$node}[$interval])
query C = count(node_cpu_seconds_total{job=~"$node, mode=“system”}) by (instance)
however dividing the two queries does not works
Appreciate your help
Hello :wave: and welcome to the forum, @hachouri
are you using transformations or expressions to perform the division?
