After upgrading Grafana from 7.4 or 8.0 to 8.1 live measurements in time series panel stopped working. The symptoms observed on Raspberry Pi ARM build as well as Linux Red Hat build. Panel remains blank and the wheel in the upper right corner of the time series panel is spinning non-stop. It used to work fine with Grafana 7.4 and 8.0.
Hi @rokitski
I will be hard to troubleshoot this without more info. Can you provide more details about the datasource, query, panel json, etc?
I reported a bug report and posted more details here: Live measurements stopped working for Grafana 8.0.4 and above on Linux · Issue #38414 · grafana/grafana (github.com)
