List of column names of SQL SERVER table with variable
Hello, I’m a new user of grafana.
After various searches I cannot find an solution to show, through the creation of a variable, the list with the names of the columns of a SQL Server table.
I tried various methods find on forum , but none of them worked.
SELECT * FROM myTable WHERE 1=0
SELECT TOP 0 * FROM myTable WHERE 1=0
SELECT COLUMN_NAME FROM INFORMATION_SCHEMA.COLUMNS WHERE TABLE_NAME = ‘table_name’
I’m using Grafana v 11.4
Thank’s for your support.
SELECT * FROM myTable WHERE 1=0 will never return a row
SELECT TOP 0 * FROM myTable WHERE 1=0 will never return a row
SELECT COLUMN_NAME
WHERE TABLE_NAME = '${table_name}'
should return rows if you have a variable name table_name
