Limiting, sorting and filtering json objects in Grafana Loki
I am storing event objects as jsons in Loki.
E.G.
	"streams": [
			"stream": {
				"stream": "operational-events"
			"values": [
					"1676976338000000000",
					"{"event_type": "test_event", "severity": "INFO", **additional_metadata, "data": {**event_data}}"
Then I would like to fetch these objects back. Is it possible to query in a way where can I sort events, limit them and filter them by the properties inside the json?
I went trough the docs but it does not seem like these features are possible.
I would expect query in this form: {stream=“operational-events”} | sort timestamp desc | limit 20
I am new to Grafana query language so I am not sure if I am missing something or these usecases are not supported.
Thanks for answers.
  1. Filtering is possible, please read LogQL | Grafana Loki documentation.
  2. It’s currently not possible to limit or sort within the query itself (you can do it externally with tool such as Grafana). There is a feature request for sorting, not sure about limit.
