I’m using Grafana v8.0.5 with Debian with InfluxDB 2 and Flux … -
I would like to get a better legend table display and be able to add Alerts.
I’m monitoring several servers with Telegraf, when I display the legend table of my chart, I would like to get less information in the field name. For example I have the host shown but I would like to get only the metric name.
I manage to do it if I add a Transform “Labels to fields”, but in this case I can’t add any Alert and I need it.
I added a Transform “Labels to Fields” but this locks the Alert system and I need it. -
What happened?
I can’t add Alert -
I would like to get a legend table with only the metric name and be able to add some Alerts -
Here is my Flux request :
from(bucket: v.defaultBucket)
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
|> filter(fn: (r) => r["host"] == "${host}")
|> filter(fn: (r) => r["_measurement"] == "cpu")
|> filter(fn: (r) => r["_field"] == "usage_guest" or r["_field"] == "usage_iowait" or r["_field"] == "usage_irq" or r["_field"] == "usage_nice" or r["_field"] == "usage_softirq" or r["_field"] == "usage_system" or r["_field"] == "usage_user" or r["_field"] == "usage_steal")
|> filter(fn: (r) => r["cpu"] == "cpu-total")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "mean")
No error in logs -
