LBAC and synthetics metrics
Hi
Im looking to see if its viable to have a grafana cloud running synthetics to which other grafana instances (OSS or cloud) can connect to get a subset of those synthetic metrics using labels.
However it would seem that they are only applied to the sm_check_info which makes any form of lbac on the actual metrics impossible
is that correct or am I missing something?
doc checked
