Grafana version is 7.5.6 and OS is Windows 10. -
I have query variables from date and to date. whenever i am opening the dashboard i want the latest dates in the from date and to date section. -
By saving the dashboard with default variables. And keeping the variables refresh as on dashboard load. -
What happened?
Some dashboards are showing the latest dates but the others are not.
If you are using Query variables
then all values are retrieved from your datasource. Do you order values in your queries for these variables somehow?
Did you specify sorting type in the properties of a variable?
