K6 & Kinesis Streams
Hi all
Has anyone used K6 to rapidly and concurrently populate Amazon Kinesis streams? I haven’t seen any libraries for KCL in JS unfortunately but was wondering if anyone has attempted this before?
Thanks
Neill
I haven’t used Kinesis, but from what I can see, it has a REST API, so it should be fairly easy to do what you want with normal HTTPS requests by k6: PutRecords - Amazon Kinesis Data Streams Service
Since you’d probably need AWS authentication, you can take a look at this simple S3 demo for how it was implemented in k6: k6 compatible awsv4 library · GitHub
There is now a pull request for kinesis support : support Kinesis, which makes it really easy to start with k6-kinesis integration. Thanks to autometa101.
