Hi
I am trying to see if I can get the following flow: k6 >> Alloy >> Mimir >> Grafana
Problem:
I can see, in Alloy “live debugging”, that k6 is pushing data in
“otelcol.receiver.otlp.default” and
“otelcol.processor.attributes.default” but unable to see data in “otelcol.exporter.otlphttp.default” as it says
“Error: Failed to connect, status code: 500, reason: the component “otelcol.exporter.otlphttp” does not support live debugging”.
I am stuck with no data in grafana, can you help - thanks in advance.
Reflections: k6 uses grps and I have exporter in “otlphttp”, I tryed changing to “otlpgrpc”.
docker-compose.yaml
services:
alloy:
image: grafana/alloy:latest
ports:
- "12345:12345" # Alloy UI
- "4317:4317" # gRPC receiver
- "4318:4318" # HTTP receiver
volumes:
- ./alloy/config.alloy:/etc/alloy/config.alloy
- alloy_data:/var/lib/alloy/data
command: [
"run",
"--server.http.listen-addr=0.0.0.0:12345",
"--storage.path=/var/lib/alloy/data",
"--stability.level=experimental",
"/etc/alloy/config.alloy"
depends_on:
- mimir
networks:
- my-observability-net
mimir:
image: grafana/mimir:latest
ports:
- "9009:9009"
volumes:
- ./mimir/mimir.yaml:/etc/mimir/mimir.yaml
networks:
grafana:
image: grafana/grafana:latest
ports:
- "3000:3000"
depends_on:
- mimir # Grafana depends on Mimir to access metrics
volumes:
- ./grafana/provisioning:/etc/grafana/provisioning
networks:
volumes:
alloy_data:
networks:
my-observability-net:
config.alloy
otelcol.receiver.otlp "default" {
grpc{}
output {
metrics = [otelcol.processor.attributes.default.input]
otelcol.processor.attributes "default" {
output {
metrics = [otelcol.exporter.otlphttp.default.input]
otelcol.exporter.otlphttp "default" {
client {
endpoint = "http://mimir:9009/api/v1/push"
livedebugging {
enabled = true
mimir.yaml
# Do not use this configuration in production.
# It is for demonstration purposes only.
multitenancy_enabled: false
blocks_storage:
backend: filesystem
bucket_store:
sync_dir: /tmp/mimir/tsdb-sync
filesystem:
dir: /tmp/mimir/data/tsdb
tsdb:
compactor:
data_dir: /tmp/mimir/compactor
sharding_ring:
kvstore:
store: memberlist
distributor:
ring:
instance_addr: 127.0.0.1
kvstore:
store: memberlist
ingester:
ring:
kvstore:
store: memberlist
replication_factor: 1
ruler_storage:
backend: filesystem
filesystem:
dir: /tmp/mimir/rules
server:
http_listen_port: 9009
log_level: error
store_gateway:
sharding_ring:
k6
K6_OTEL_GRPC_EXPORTER_INSECURE=true K6_OTEL_METRIC_PREFIX=k6_ \
k6 run --out experimental-opentelemetry ./demo.js
