JSON API in that JSONPath to query data using $.[?(@.Name==“variable”)]
I use JSON API in that JSONPath to query data using $.[?(@.Name==“variable”)] but I still got no data
Sample data below,
	"Assign_status": 0,
	"Car_Model": "Lexus ES",
	"Vehicle_Type": "Sedan"
	"Assign_status": 1,
	"Car_Model": "Dodge Challenger",
	"Vehicle_Type": "Muscle Car"
	"Assign_status": 1,
	"Car_Model": "Toyota Corolla",
	"Vehicle_Type": "Sedan",
	"Assign_status": 0,
	"Car_Model": "Ford Mustang",
	"Vehicle_Type": "Coupe",
in this case,
I create a panel in dashboard and query the data by using JSONPath:
$.[?(@.Assign_status == ‘0’)]
$.[?(@.Assign_status == ‘1’)] , but it shows Eval [?(expr)] prevented in JSONPath expression.
find assign is 1 and unassign is 0 and both should count
might be better using infinity plugin and use uql
https://grafana.github.io/grafana-infinity-datasource/docs/filters
car dealer
hi,yosiasz
I need to find only “Assign_status” column and I want to count how many zeros and ones are there in a single panel. I should view both counted zeros and ones
sample data ,
“Assign_status”: 0,
“Car_Model”: “Lexus ES”,
“Location_ID”: 5,
“Vehicle_ID”: 10,
“Vehicle_Type”: “Sedan”,
“Year_Model”: 2022
“Assign_status”: 1,
“Car_Model”: “Dodge Challenger”,
“Location_ID”: 4,
“Vehicle_ID”: 9,
“Vehicle_Type”: “Muscle Car”,
“Year_Model”: 2020
“Assign_status”: 1,
“Car_Model”: “Toyota Corolla”,
“Location_ID”: 2,
“Vehicle_ID”: 8,
“Year_Model”: 2018
“Assign_status”: 0,
“Car_Model”: “Ford Mustang”,
“Location_ID”: 3,
“Vehicle_ID”: 7,
“Vehicle_Type”: “Coupe”,
“Year_Model”: 2023
“Assign_status”: 1,
“Car_Model”: “Chevrolet Malibu”,
“Year_Model”: 2017
cool. here is the docu for uql try it out tp find filter by status and how to do count
https://grafana.github.io/grafana-infinity-datasource/docs/uql
then when you havw tried something and are stuck we can help you.
