Good evening everyone,
I came across a situation that I am not able to adjust according to the need I need at the moment, I did research on the subject on google and right here on the forum.
The point is:
I get data from a select that I do through an item in the database.
The select is this:
SELECT distinct(P.orderid)
FROM
tinf_orderlog P
ONDE
NOT EXISTS (
** SELECT**
** V.orderid**
** FROM**
** tinf_order_payment V**
** ONDE**
** V.orderid = P.orderid**
This select does searches in a table what is not in the other and returns the records in zabbix as Text, it brings me in json and then I make the following substitutions so that I only have the record.
Print:
Records that are separated by ,:
67285675,67699824,67500341,67457902,67647474,67582015,67507920,67791488,67166257,67509708,67172610,67664555,67613726,67613696,67778807,67418985,67538400,67764841
These records come from various hosts.
My difficulty is to make them appear as a table and to be able to filter for these records and from several hosts.
I would like it to stay this way
