Today i have installed an Dash board, but it does not give me the interface name, i guess this dash board is not for cisco switches or at least the one i am using.
https://grafana.com/dashboards/1124
I found the problem
in Graph Matrix it has bellow
irate(ifHCInOctets{job=‘snmp’,instance=‘$Device’,ifDescr=~‘$Interface’}[5m])
in template under interface
query_result(ifInOctets{job=“snmp”,instance=“$Device”})
Regex : .ifDescr="(.?)",.*
but when i run bellow matrix in Prothemeus the “ifInOctets” , it does not have any values such as ifDescr.
ifInOctets{ifIndex=“10001”,instance=“10.0.0.0.”,job=“snmp”} 961966007
ifInOctets{ifIndex=“10002”,instance=“10.0.0.0”,job=“snmp”} 4328834
the *ifDescr value comes from matrix *ifDescr , so the query in template does not get any values.
ifDescr{ifDescr=“FastEthernet0/11”,ifIndex=“10011”,instance=“10.0.0.0”,job=“snmp”} 1
ifDescr{ifDescr=“FastEthernet0/12”,ifIndex=“10012”,instance=“10.0.0.0”,job=“snmp”} 1
i think, the way it should be fix is some how join 2 matrix ![network|689x343]
matrix ifInOctets : to get the ifindex number then search this infindex number in matrix ifDEscr to get the interface name
how can i do this ? or is there any other better way ?
then end Goal is to achieve the interface name and show the interface name in the graph!
