Issues measuring disk usage in Nagios/Grafana with check_nrpe
Good morning, I have a Nagios 4.3.4 service defined as follows to measure disk usage:
define service{
       use                      generic-service
       #host_name                MyServer
       hostgroup_name           MyHostGroup
       service_description      MyDescription
       check_command            check_nt!USEDDISKSPACE!-l c -w 90 -c 95
This works fine, but I can only generate alerts based on percentage of used space and I have been asked to generate alerts when available space is reduced to an amount in GB, rather than a percentage.
So, I created revised the service definition and made it use a newly defined command as follows:
define service{
       use                      generic-service
       #host_name                MyServer
       check_command            Win_Disk_Space_C
define command{
        command_name Win_Disk_Space_C
        command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -t 60 -p 5666 -c check_drivesize -a drive=C: 'warning=free<2G' 'critical=free<1G' show-all 'perf-config=*(unit:G)' detail-syntax='{${drive_or_name} ${free} free / ${size} total}' top-syntax='${status}: ${problem_list}'
This reports correct usage values in Nagios Core 4.3.4 using NSClient++ 0.4.3.143, but when I pass the data into Grafana via Graphios+InfluxDB, it returns completely incorrect values for disk usage (e.g. 45GB instead of 2GB on a 10GB disk!)
Can anyone see anything wrong with my command definition, or advise if the issue might be resolved by upgrading to NSClient++ 0.5…1.44?
Here’s some typical Nagios CL output:
OK: {C: 21.552GB free / 39.656GB total}|'C: free'=21.5524G;5;2;0;39.65624 'C: free %'=54%;13;5;0;100
Update: I’ve upgraded to NSClient++ 0.5.1.44 on this host, but it’s still reporting erroneously within Grafana.
Thanks for taking a look!
Pete
