Grafana version 9.5.8 and windows operating system -
In diagram visualization, the values separated options only available as “&” and not possible with “,” . For you reference I will mention it below
BB904[BB904]==>BB903[BB903] , BB902[BB902] -
By installing Diagram plugin. -
What happened?
I can’t able to separate the label values by using “,” -
I want to separate the values should separate by using “,” instead of “&” -
In this configuration, BB904[BB904]==>BB903[BB903] & BB902[BB902]
I’m using “&” to separate the value on Diagram visualization on grafana dashboard. But I want to achieve it through “,” (comma) -
No errors. But It won’t show the diagram when I use BB904[BB904]==>BB903[BB903] , BB902[BB902]
