Using a table from a mysql db here
So I’ve got this issue which is basically this, data in the tables is sent once every refresh time period, so tables without filters etc everything works as expected. When using filters though, unlike the data queries which are sent every refresh period, the queries for variables appear to only be sent once per loading the page. Hence, if any data with a new value of a filterable column arrives while this page is open, it will not display until the page reload. The issue here is having to refresh the page every time we want new data which is something I’d definitely like to avoid. If anyone had any suggestions.
Using grafanav7.4.5 on redhat 7.9 -
Not needing to refresh page for new results using filtering -
Not sure yet. - What happened?
Data not being refreshed when using filters until page is refreshed - What did you expect to happen?
Filtered data refreshes on timed refresh
Thanks a lot for reading
