I am using <Segment/> from @grafana/ui.I would like to know is there a way to make this component disabled based on the certain value of state,because i was unable to find the disabled attribute in <Segment/>
Hello @abhinandan13
Please try regular disabled attribute:
<Segment disabled={value} ...
I use it for UI component:
Regards,
V.
@vsergeyev thanks for the reply,but when i use the disable attribute in <Segment> i get an error saying
Property ‘disabled’ does not exist on type ‘IntrinsicAttributes & SegmentSyncProps & { children?: ReactNode; }’.
Here is a snapshot of my code
Segment doesn’t have a disabled prop. You can se the list of the available props at grafana/ui storybook page: https://developers.grafana.com/ui/latest/index.html?path=/docs/data-source-segment-segmentsync--array-options
Setting className or overriding onChange may help to make it disabled:
