Is there a difference between `| keep` and `by ()`?
Hi! Consider the following queries:
max_over_time(
   {job="LDCSEC12"}
   | regexp `(?P<time>[^,]*),MinMaxAvg,(?P<category>[^,]*),(?P<name>[^,]*),(?P<count>[^,]*),(?P<min>[^,]*),(?P<avg>[^,]*),`
   | unwrap avg [$__auto]
) by (job)
vs:
max_over_time(
   {job="LDCSEC12"}
   | keep job, avg
Is there a difference between them?
I do not see any difference in the results not in execution time. Are they equivalent? Is actually keep slightly preferred, as it removes the labels at an “earlier” (execution wise) step?
Functionally the two queries are the same. The keep keyword means to keep the labels specified and discard the rest. Generally not needed in normal queries. The only place I find useful is when creating rules in ruler sometimes you might wish to remove unnecessary labels so they don’t show up in your alert then it becomes useful.
