Is it possible to plot multiple data of redis?
Hello.
I want to plot multiple data of Redis on a graph.
I set hash data on redis like this.
key : hoge
field/value:
test1/10
test2/20
test3/30
test4/40
I want to plot all data on a panel and monitor by streaming but can’t.
It can’t plot all data on a graph when I try to get multiple data(used by “hmget” command).
I want to plot like this.
Is it possible?
Hello @kamadaharu, my name is Mikhail and I am one of the developers of Redis Data Source.
I have a similar question regarding plotting hash data on the graph using the HGETALL command.
Could you please open a feature request to support the HMGET Command to plot on the graph panel: https://github.com/RedisGrafana/grafana-redis-datasource/issues
Thank you.
I have similar question. I’m working using redis’ lists, in my case I get the value using (CLI) “LRANGE key idx idx”, I can’t chart it but I can see in a table.
Best regards.
Nelson, thank you for submitting the issue. I will take a look and get back to you shortly.
