I need to display dynamically, a set of images served by Node-RED using the following URL http://172.19.0.4:1880/images?time=${__to}. I have deployed Grafana and Node-RED through Docker and have placed them on the same subnet. However, I only have the 3000 gateway open to the internet. How could I redirect the URL to load the image to the Grafana internal network instead of the browser network (from usser side)?
Note: The Grafana IP address internal to the Docker is 172.19.0.3. I have further performed the test from Grafana shell
curl http:// 172.19.0.4:1880/images?time=1727095791358
Grafana resolves to see the file.
My question is how to redirect the internal IP instead of the public one.
I have used a “text” panel with the following HTML code
<img src=“http://172.19.0.4:1880/images?time=${__to }” alt=“Latest Camera Image” />
