Interactive Table -- Experimental UI
    I am trying to add the Interactive Table to a custom plug-in of mine.
    I have tried adding
import {InteractiveTable} from '@grafana/ui'
and
import {InteractiveTable} from '@grafana/experimental'
after running
yarn add @grafana/experimental
  • What happened?
    Interactive Table is not an exported member.
    Webpack App
Are we not able to use Interactive Table yet?
Update: I resolved the issue by running
yarn add @grafana/ui
which seems to have updated the package to include InteractiveTable.
