I have a dashboard with several variables, with these variables we are applying Calculate transformations to show the mean, min, max, …
It’s possible that the users can change this value from the dashboard? For example with a variable or something like that?
Hi @fmondelo
Apologies but I’m not sure I follow you. Can you explain in more detail what you are trying to achieve? Maybe some screenshots?
Sorry @mattabrams for the delay, the problem is that my users want to view the panel with different “transformations” of the same measures, but for that, I have to add several panels with different transformations for each possible combination, for example:
I need to have a combo or something that the users can select what kind of transformation they want. Is possible?
