I am using Grafana (8.1.15) to visualize seismic data, which are stored locally using a JANE database and the mseed-format for the data. So far I couldn’t add it successfully as a data source. I know JANE relies on PostGreSQL on some level, but don’t know how to post queries for this case exactly. Any ideas? Would be highly appreciated!
thanks for your reply. Have to check out the REST API. Didn’t work with it before.
Why should the JSON API as datasource work? I contacted JANE support. They also hinted towards the REST API. Eventually it depends if Grafana can handle .mseed files (seismic data) as well…
