Step 1 provision Kubernetes Cluster
- Click the Catalog button on the top
- Select Service from the catalog
- Search for Kubernetes Service and click on it
You are now at the Kubernetes deployment page, you need to specify some details about the cluster
Choose a plan standard or free , the free plan only has one worker node and no subnet, to provision a standard cluster, you will need to upgrade you account to Pay-As-You-Go
To upgrade to a Pay-As-You-Go account, complete the following steps:
In the console, go to Manage > Account.
Select Account settings, and click Add credit card.
Enter your payment information, click Next, and submit your information
Choose classic or VPC , read the docs and choose the most suitable type for yourself
Now choose your location settings.
Choose Single or Multizone, in single zone your data is only kept in on datacenter, on the other hand with Multizone it is distributed to multiple zones, thus safer in an unforseen zone failure
If you wish to use Multizone please set up your account with VRF or enable Vlan spanning
If at your current location selection, there is no available Virtual LAN, a new Vlan will be created for you
Choose a Worker node setup or use the preselected one, set Worker node amount per zone
Choose Master Service Endpoint , In VRF-enabled accounts, you can choose private-only to make your master accessible on the private network or via VPN tunnel. Choose public-only to make your master publicly accessible. When you have a VRF-enabled account, your cluster is set up by default to use both private and public endpoints.
Give cluster a name
Give desired tags to your cluster.
Click create
Wait for you cluster to be provisioned
Your cluster is ready for usage
Step 2 deploy IBM Cloud Block Storage plug-in
The Block Storage plug-in is a persistent, high-performance iSCSI storage that you can add to your apps by using Kubernetes Persistent Volumes (PVs).
Select Software from the catalog
Search for IBM Cloud Block Storage plug-in and click on it
On the application page Click in the dot next to the cluster, you wish to use
Click on Enter or Select Namespace and choose the default Namespace or use a custom one (if you get error please wait 30 minutes for the cluster to finalize)
Give a name to this workspace
Click install and wait for the deployment
Step 3 deploy Grafana
We will deploy MySQL on our cluster
Search for Grafana and click on it
Please select IBM Kubernetes Service
Give a unique name to workspace, which you can easily recognize
Select which resource group you want to use, it’s for access control and billing purposes.
Give tags to your Grafana,
Click on Parameters with default values , You can set deployment values or use the default ones
Please set the Grafana root password in the parameters
Please change the service.type from ClusterIP to LoadBalancer in the parameters
After finishing everything, tick the box next to the agreements and click install
The Grafana workspace will start installing, wait a couple of minutes
Your Grafana workspace has been successfully deployed
Verify Grafana installation
Go to Resources in your browser
Click on Clusters
Click on your Cluster
Now you are at you clusters overview, here Click on Actions and Web terminal from the dropdown menu
Click install - wait couple of minutes
Click on Actions
Click Web terminal → a terminal will open up
Type in the terminal, please change NAMESPACE to the namespace you choose at the deployment setup:
$ kubectl get ns
$ kubectl get pod -n NAMESPACE -o wide
$ kubectl get service -n NAMESPACE
- Running Grafana service will be visible
- Copy the External IP and Port number, you can access the website on this IP
- Paste it into your browser
- Grafana welcome message will be visible
