Installation on Debian on x86-64 NUC
I want to install Grafana on a x86-64 system (NUC) with Debian 9.
But the Link x86-63
grafik
shows only AMD64 respositories:
What can I do in this case?
Many thanks in advance for your help!
Henry
Is the NUC running only an x86 installation of Debian?
If it is running x86-64, the amd64.deb file should work.
Thanks for your quick responce.
The NUC running with an x86 Installation of Debian:
grafik
I hope it works for Grafana?
Now it works, I’ve installed an 64bit Debian!
Thanks a lot and best regards
Henry
