Inner join yields only one row per match
  • Grafana 9.4.12
  • OS: Azure Managed Grafana
    Build a joined table from an Azure Resource Graph Query and a Prometheus.
    The azure resource graph allows querying for security assessments on scanned container registry images. The assessments only refer to the sha256 docker image digests - not the tagged image “name”.
    To limit alerts we want to limit them to currently running images, using a prometheus query.
    I’ve built mixed datasource queries as below:
Both queries themselves seem fine.
To join the two results we use Join by Field on image_id with mode inner.
Without the transformation we get multiple alerts for each image. With the transformation switched on the join partly seems to work, but not matter what image and how many “input rows” there are - only one row per image_id is produced by the join.
  • What happened?
    see above
    A “proper” inner join, that yields all rows from both sides with a matching image_id
Same problem here. I need to join 2 tables by one value. However it picks only one joined row. If in table1 I have 2 values = foo, when joining only 1 value is joined. The other one disappears.
