What Grafana version and what operating system are you using? v9.0.6 / OpenBSD v7.2
What are you trying to achieve? Graph the data for exactly one Icinga 2 disk service (of exactly one host of course)
How are you trying to achieve it? Just after FROM disk I add service=disk:/ to WHERE and click on + to also add a hostname filter
What happened? The selector of the appeared search input says No options found.
What did you expect to happen? It lets me also choose hostname.
Hello all!
This is some of my input data:
tower# influx
Connected to http://localhost:8086 version unknown
InfluxDB shell version: unknown
> use icinga2
Using database icinga2
> select * from disk;
time hostname metric service unit value
1668971792000000000 tower /home disk:/home bytes 0
1668971828000000000 tower /raid1 disk:/raid1 bytes 60666000000
1668971962000000000 tower /usr disk:/usr bytes 1236000000
1668971983000000000 tower /tmp disk:/tmp bytes 0
1668972053000000000 mx.al2klimov.de / disk:/ bytes 10137000000
1668972099000000000 tower /usr/obj disk:/usr/obj bytes 0
1668972137000000000 tower /usr/X11R6 disk:/usr/X11R6 bytes 271000000
1668972155000000000 tower /usr/src disk:/usr/src bytes 0
1668972165000000000 tower / disk:/ bytes 111000000
1668972208000000000 tower /var disk:/var bytes 53000000
1668972241000000000 tower /usr/local disk:/usr/local bytes 820000000
1668975304000000000 tower /home disk:/home bytes 0
1668975329000000000 tower /raid1 disk:/raid1 bytes 60666000000
1668975507000000000 tower /tmp disk:/tmp bytes 0
1668975560000000000 tower /usr disk:/usr bytes 1236000000
1668975606000000000 mx.al2klimov.de / disk:/ bytes 10137000000
As you see there are at least the tags hostname and service. I can filter for any of them, but not for both. Has anyone ever seen such behavior?
Best,
A/K
