I am trying to transfer this data to influxdb by pulling data from an address, but I could not transfer the data to influxdb even though I pulled the data. I am working in Scala language, service is running but data is not coming to influxdb. I want the monitoring EMC Recover Point
Could you help me with this please?
My Collector.xml code
<?xml version="1.0" encoding="UTF-8"?>
<collector>
<extractors>
<extractor name="rp">
<baseUrl>https://EMC-RP-IP/fapi/rest/5_1</baseUrl>
</extractor>
</extractors>
<outputs>
<output name="influxdb">
<type>influxdb</type>
<address>localhost</address>
<port>8086</port>
<dbname>RP</dbname>
</output>
</outputs>
<systems>
<system>
<name>rp01</name>
<class>rp</class>
<interval>10 min</interval>
<address>EMC-RP-IP</address>
<username>admin</username>
<password>pass</password>
<ver>5_1</ver>
</extractor>
<output>influxdb</output>
</system>
</systems>
</collector>
My Influxdb.scala code
package universalstoragecollector
import scala.util.Properties.propOrElse
import scala.util.Try
import java.util.concurrent.TimeUnit
import org.influxdb.{InfluxDB, InfluxDBFactory}
import org.influxdb.InfluxDB.ConsistencyLevel
import org.influxdb.dto.Point.Builder
import org.influxdb.dto.{BatchPoints, Point}
// Output to InfluxDB
class Influx(name: String, config: Map[String, String],
sysConfig: Map[String, Option[String]])
extends Output(name, config, sysConfig) with Logger {
val loggerFile: String = propOrElse("USC_HOME", "") + "log/collector-error.log"
// Common parameters
val address: Option[String] =
if (config.contains("address"))
Some(config("address"))
else
None
val port: Option[Int] =
if (config.contains("port"))
Some(config("port").toInt)
else
None
val dbname: Option[String] =
if (config.contains("dbname"))
Some(config("dbname"))
else
None
var influxDB: InfluxDB = _
// Validation by common parameters
//def isValid: Boolean = config.contains("address") & config.contains("port") &
//config.contains("dbname")
// Connection initialization before data output
def start(): Unit = {
influxDB = InfluxDBFactory.connect("http://Influx-IP","username","pass")
influxDB.open()
String databaseName = "foo"
influxDB.query(new Query("CREATE DATABASE " + databaseName, databaseName))
influxDB.setDatabase(databaseName)
// Convert numbers in data from String type to Double type
def parseDouble(s: String): Option[Double] = Try { s.toDouble }.toOption
// Output data comes in 'msg' and 'data' structures
def out(msg: Map[Int, (String, String)], timestamp: Long, data: Map[String, String]): Unit = {
val header: Map[String, String] = (msg.values map (v => v._1 -> v._2)).toMap
val batchPoints: BatchPoints = BatchPoints
.database(databaseName)
.retentionPolicy("autogen")
.consistency(ConsistencyLevel.ALL)
.build()
val point: Builder = Point.measurement(header("measurement"))
.time(timestamp.toLong, TimeUnit.SECONDS)
.tag("storage", sysConfig("name").get)
.tag("class", sysConfig("class").get)
if (sysConfig("type").isDefined) point.tag("type", sysConfig("type").get)
(header.keySet - "measurement") foreach {k => point.tag(k, header(k))}
data.foreach {p =>
if (parseDouble(p._2).isDefined) point.addField(p._1, parseDouble(p._2).get)
else point.addField(p._1, p._2)
batchPoints.point(point.build())
influxDB.write(batchPoints)
// Closing connection after data output
def stop(): Unit = {
influxDB.close()
And my logs:
Wed Nov 30 09:24:36 UTC 2022 rp01, /clusters/statistics: java.util.NoSuchElementException: key not found: measurement
Wed Nov 30 09:24:37 UTC 2022 rp01, /rpas/statistics: java.util.NoSuchElementException: key not found: measurement
Wed Nov 30 09:24:37 UTC 2022 rp01, /groups: net.liftweb.json.MappingException: No usable value for innerSet
No usable value for groupCopiesInformation
No usable value for vmsInformation
Do not know how to convert JObject(List(JField(vmUID,JObject(List(JField(uuid,JString(500823dd-6738-b445-c705-7ad0d2b4e67c)), JField(virtualCenterUID,JObject(List(JField(uuid,JString(1a5e7115-0def-4796-b155-89d0c20e4ea5)))))))), JField(vmName,JString(YalcinMustafa_Management-win)), JField(vmBiosUuid,JString(4208652e-3aae-11bb-03a8-47d5ad33e1fc)))) into class java.lang.String
Thanks in advance
