InfluxDB- Trying to create OS variable which will display windows and linux host based on OS selection
Hi All,
Grafana version - 9.5.1?
Trying to create OS variable which will display windows and linux host based on OS selection.
  1. I have created varriable name os which is showing os details i.e windows and linux
  2. Created another varriable host and using with below query.
    import “influxdata/influxdb/schema”
    schema.tagValues(butket: “sourcebucket” , tag: $“os”
  3. Preview of value showing nothing
  4. as per my understanding it should display the host name.
Thanks & Regard
