I recently installed the InfluxDB (Flux) Datasource [BETA] plugin. I run an on-prem InfluxDB 1.8.0 instance.
The setup instructions for this plugin are not clear when it comes to configuring this datasource plugin for InfluxDB 1.8. Near as far as I can tell, there are no “v2” APIs in InfluxDB 1.8 to retrieve an organization.
To setup the datasource, I used field values similar to the following:
- URL:
http://localhost:8086
(I also triedhttp://localhost:8086/api/v2/query
) - Organization:
null
- Default Bucket:
my-bucketname/autogen
- Max Series:
null
- Token:
null
Whenever I click Save & Test, I receive the following error:
500 Internal Server Error: {“error”:“panic”: column retentionPeriod:int is not of type string"}
I thought maybe this was just a “hardcoded” query that was sent to test the datasource connectivity. So I tried to create a dashboard using the datasource. However, any dashboard queries result in the same error message as above.
Am I doing something wrong? I’m not sure I have any retention policy configured on this instance yet. Is that required?
Any help would be much appreciated.
