I have a local and cloud versions of influxdb which hold the same data. I have been developing the grafana pages using the cloud data source. I want to move (or create) the same grafana pages on the local version.
The grafana builder page is different between cloud and local versions.
The local version uses a more simplistic version with drop downs etc.
Both do the same this but I have more complete code in other grafana panels that can not be replicated using the drop down options available in the local version.
How do I get the code version for the local grafana version?
Thanks in advance
Thanks. I searched for something like this for hours. I have changed it to flux, added the db details and put in default bucket but now I get
404 Not Found: 404 page not found error reading buckets
Hi grant2
I tried to get to the sign on page http://10.1.1.7:8086/signin and I get the 404 page not found in the browser. I host on a raspberry pi. I checked the ip and definitely correct. The data get loaded from a small python code and this all looks correct. It was working fine and now I can’t connect after changing InfluxQL to Flux.
I have reset influx to
