9.3.1 -
Display a timeseries usingincrease
and a multi value variable -
Use query
increase(executor_completed_tasks_total{instance=~"$instance", name="Alpine-EventService"}[$__rate_interval])
What happened?
No data is being displayed. When I remove theincrease
part from the query it starts working.
ie
Also when I change$instance
into a single value variable and use exact match instead of regex match it also works.
ie
increase(executor_completed_tasks_total{instance="$instance", name="Alpine-EventService"}[$__rate_interval])
All other panels work fine with a multi value $instance
and a =~
match in their queries. Problem seems to happen only for the panels that have increase
in their query.
Usingincrease
on top of a working query with a multi value variable should work. -
No errors, just no data. Query inspector shows no data being returned from backend. -
