I am using the patch from #7863 https://github.com/grafana/grafana/pull/7863#issuecomment-354004166 as i am using Nested queries in Elasticsearch
Grafana version: 4.3
i am using User HTTP API. In it, i am using the ‘Actual user’ API which returns the following response:
"id": 0,
"email": "super@localhost",
"name": "",
"login": "super",
"theme": "",
"orgId": 1,
"isGrafanaAdmin": true
But when is use the ‘Search users’ API, it returns the following response:
"id": 1,
"name": "",
"login": "super",
"avatarUrl": "/grafana/avatar/214d0b9e3d7df8a9fa4a4ee0020d3138",
"isAdmin": true,
"lastSeenAt": "2018-12-28T12:28:12+05:30",
"lastSeenAtAge": "2m"
Note that the id in ‘Actual user’ is returned as 0 and in ‘Search users’ is returned as 1 for the same user email i.e. super. I even checked user on dashboard and there exists only one user i.e. super
Even when i use the ‘Get single user by id’ API like this:
URL : localhost/grafana/api/users/1
I get the following response:
"id": 0,
"name": "",
"login": "super",
"theme": "",
"orgId": 1,
What might be the reason behind such inconsistency in User id ??
I have to use this patched version of Grafana as Grafana doesn’t support Nested queries and only this patch has the fix.
Thanks and regards,
Kaiwalya
