In which object storage bucket are the indexes stored?
I’m using TSDB index and i’d like to understand in which object storage bucket are the indexes stored (in the default configuration).
Thanks.
Seb.
Index is stored in whatever storage you specify in the index configuration. A common way to do this is to define an S3 bucket (assuming you are using S3) in common configuration block, then reference it in your index configuration. For example (mock config):
common:
  storage:
    s3:
      bucketnames: <BUCKET_NAME>
      region: <REGION>
      sse_encryption: true
      s3forcepathstyle: true
schema_config:
  configs:
    store: tsdb
    object_store: s3
    schema: v12
    index:
      prefix: index_
      period: 24h
Thanks for your answer!
Seb.
