If I used AND query between two servers, then the data points are unable to write to the dashboard. While giving two different servers using AND query we are not getting data points. But it is working with one server only.
What datasource? It’s very likely an in issue with how you write the query. Make sure you read the query language docs for the datasource your using.
Hey torkel,
we are using influxdb datasource.
