Improve PDC Agent Deployment
I had to add the namespace field manually to the file downloaded from https://raw.githubusercontent.com/grafana/pdc-agent/main/production/kubernetes/pdc-agent-deployment.yaml. Without this field, the deployment would fail because it lacked the necessary namespace configuration.
Having a Terraform example and better documentation or support for cloud environments would greatly simplify implementations like this.
From my perspective, grouping agents by namespace would be a more efficient approach. Currently, I need to create a separate token for each group of agents, which adds complexity. Providing a way to manage tokens at a namespace level or grouping agents would streamline deployments and make it easier to manage resources in large environments.
data "local_file" "pdc_agent_deployment" {
  filename = "${path.module}/manifest/pdc-agent-deployment.yaml"
resource "kubernetes_manifest" "pdc_agent_deployment" {
  manifest = yamldecode(
    templatefile(
      "${path.module}/manifest/pdc-agent-deployment.yaml",
        namespace = kubernetes_namespace.metrics.id
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: ${ namespace }
  labels:
    app: grafana-pdc-agent
spec:
  replicas: 1
  selector:
    matchLabels:
  strategy:
    rollingUpdate:
      maxSurge: 1
      maxUnavailable: 0
    type: RollingUpdate
  template:
    metadata:
      labels:
    spec:
      containers:
        - name: grafana-pdc-agent
          env:
            - name: TOKEN
              valueFrom:
                secretKeyRef:
                  key: token
            - name: CLUSTER
              valueFrom:
                secretKeyRef:
                  key: cluster
            - name: HOSTED_GRAFANA_ID
              valueFrom:
                secretKeyRef:
                  key: hosted-grafana-id
          args:
            - -cluster
            - $(CLUSTER)
            - -token
            - $(TOKEN)
            - -gcloud-hosted-grafana-id
            - "$(HOSTED_GRAFANA_ID)"
          image: grafana/pdc-agent:latest
          imagePullPolicy: Always
          resources:
            limits:
              memory: 1Gi
            requests:
              cpu: 1
              memory: 1Gi
          securityContext:
            allowPrivilegeEscalation: false
            privileged: false
            runAsNonRoot: true
            capabilities:
              drop:
                - all
      securityContext:
        runAsUser: 30000
        runAsGroup: 30000
        fsGroup: 30000
