Grafana Version: 8.3.3
operating system: Ubuntu
wizzy versioin: 0.7.0 -
I was using wizzy cli tool to import the dashboards from url: localhost:3000 running on my machine
Note: i could able to download orgs and datasources but getting issue with dashboards -
I have added username: admin and password:admin as well as the url: localhost:3000 in wizzy conf -
What happened?
Getting Error while running wizzy import dashboards
✘ Dashboard DashboardName import failed: Error: Server responded with status code 404:
“message”: “Not found”
Note : i can see the list of dashboards using wizzy list dashboards
I expect to download the dashboards from grafana api to my local repository -
I donno where exactly the issue i. i tried with grafana 7.0 versions i could able to download the dashboards but after grafana 7 say v8 and v9 i couldn’t able to import -
i have followed the wizzy website to acheive this
https://grafana-wizzy.com
