My System:
Windows Server 2019
Grafana 8.0.0
Image-Renderer-Engine 3.0.0
Installation behing a WEB-Proxy Firewall
How do i proceed?
Stop Grafana (sc stop grafana)
Change to Grafana Path (cd \Program Files\GrafanaLabs\grafana\bin)
Install plugIn (grafana-cli.exe plugins install grafana-image-renderer)
Start Grafana (sc start grafana)
Check PlugIn: installed and signed
Check PlugIn: now it says: Modified Signature
Solution for this Problem:
9. Stop Grafana
10. Delete MANIFEST.TXT file
11. add allow_loading_unsigned_plugins = grafana-image-renderer to my custom.ini
12. Start Grafana
13. Check PlugIn: installed and unsigned
Should i post this to GitHub?
Hi, Yes I think that if this bug is not going away that you should report it in the image-renderer repo.
Here is a related issue that you might want to check out from two days ago. Thanks for noting this!
opened 01:20PM - 09 Jul 21 UTC
Please use this template to create your bug report. By providing as much i… nfo as possible you help us understand the issue, reproduce it and resolve it for you quicker. Therefor take a couple of extra minutes to make sure you have provided all info needed.
PROTIP: record your screen and attach it as a gif to showcase the issue.
- Questions should be posted to: https://community.grafana.com
- Use query inspector to troubleshoot issues: https://bit.ly/2XNF6YS
- How to record and attach gif: https://bit.ly/2Mi8T6K
**What happened**:
Restart Grafana service, or computer. Grafana front end says grafana-image-renderer not installed. grafana-cli might agree, or might show it installed. grafana-image-renderer folder and files exist on disk without any apparent changes since before service was restarted.
**What you expected to happen**:
Once installed, grafana-image-renderer continues to show as installed and work after service / computer restarts.
**How to reproduce it (as minimally and precisely as possible)**:
Install v8.x and grafana-image-renderer on Windows (I'm using MySQL, and Grafana was upgraded from at least v7, v6 before that - no idea if relevant).
```loop to here```
Restart Grafana service once to activate grafana-image-renderer.
Check front end and confirm grafana-image-renderer installed and working.
Restart Grafana service.
Check front end and observe that it says grafana-image-renderer is not installed.
Run ```grafana-cli.exe plugins ls``` and observe it may / may not show grafana-image-renderer as installed. Even if it's shown as installed, it doesn't work.
Run ```grafana-cli.exe remove grafana-image-renderer``` and observe from result that it was removed, even if ```grafana-cli.exe plugins ls``` said it wasn't installed.
Run ```grafana-cli.exe remove grafana-image-renderer``` and observe the file not found error because it tried to remove a file that wasn't there - observe how this is different to the run above.
Run ```grafana-cli.exe install grafana-image-renderer``` and observe success reported, and prompt to restart Grafana service to activate plugin.
Loop back to ```loop to here``` in this list. Repeat until you're convinced I'm not making this up.
**Anything else we need to know?**:
As I recall, following the upgrade of 7.x to 8.0.2 the plugins refused to run and I think I had to delete the plugins.json from the plugins root folder and let it rebuild before they would work. All other plugins work fine now - only grafana-image-renderer gives problems.
**Environment**:
- Grafana Image Renderer version: 3.0.1
- Grafana version: 8.0.1 - 8.0.5
- Data source type & version: MySQL 5.7 DB for Grafana data. Graph data sources include MySQL and InfluxDB
- OS Grafana is installed on: Windows Server 2012 R2
- User OS & Browser: Window 10 AMD64, Chrome 91.0.4472.124 (Official Build) (64-bit)
- Grafana plugins:
grafana-clock-panel ←[33m@←[0m 1.1.3
grafana-image-renderer ←[33m@←[0m 3.0.1
grafana-piechart-panel ←[33m@←[0m 1.6.2
grafana-polystat-panel ←[33m@←[0m 1.2.5
grafana-worldmap-panel ←[33m@←[0m 0.3.3
- Others:
briangann-datatable-panel ←[33m@←[0m 1.0.3
briangann-gauge-panel ←[33m@←[0m 0.0.9
farski-blendstat-panel ←[33m@←[0m 1.0.3
jasonlashua-prtg-datasource ←[33m@←[0m 4.0.4
michaeldmoore-annunciator-panel ←[33m@←[0m 1.1.0
michaeldmoore-multistat-panel ←[33m@←[0m 1.7.2
mtanda-heatmap-epoch-panel ←[33m@←[0m 0.1.8
mxswat-separator-panel ←[33m@←[0m 1.0.1
neocat-cal-heatmap-panel ←[33m@←[0m 0.0.4
petrslavotinek-carpetplot-panel ←[33m@←[0m 0.1.2
satellogic-3d-globe-panel ←[33m@←[0m 0.1.1
savantly-heatmap-panel ←[33m@←[0m 0.2.1
vonage-status-panel ←[33m@←[0m 1.0.11
Hi @ulrichc
I have seen that you had the same issue than me. I would like to confirm with you when you applied steps from 9 to 13 the image-render plugin works again?
Please let me know your comments due to that I’m facing the same issue and I have tried to call the chromium with different arguments but I have not been a lucky guy.
Have a nice day!
