Hi, I’m getting this error when querying elasticsearch cloud deployment from grafana cloud (I’m copying the whole trace at the end of the post):
type:“illegal_argument_exception”
reason:“field expansion matches too many fields, limit: 1024, got: 1433”
There is a workaround that recommends updating some setting on the database (https://github.com/elastic/kibana/issues/15863), but unfortunately this setting cannot be changed on cloud deployment.
What surprises me is that I can make the same query against the same index (with no setting updated on the database) from Kibana. So I guess that some parametrization might be done from the dashboarding application to overcome this issue.
Any idea?
Thanks a lot!
“xhrStatus”: “complete”,
“request”: {
“method”: “POST”,
“url”: “api/datasources/proxy/3/_msearch?max_concurrent_shard_requests=5”,
“data”: “{“search_type”:“query_then_fetch”,“ignore_unavailable”:true,“index”:“twitter_marvel_elastic_example”}\n{“size”:0,“query”:{“bool”:{“filter”:[{“range”:{”@timestamp":{“gte”:“1572868208628”,“lte”:“1572871808628”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:""}}]}},“aggs”:{“2”:{“date_histogram”:{“interval”:“5s”,“field”:"@timestamp",“min_doc_count”:0,“extended_bounds”:{“min”:“1572868208628”,“max”:“1572871808628”},“format”:“epoch_millis”},“aggs”:{}}}}\n"
“response”: {
“took”: 12,
“responses”: [
“error”: {
“root_cause”: [
“type”: “query_shard_exception”,
“reason”: "failed to create query: {\n “bool” : {\n “filter” : [\n {\n “range” : {\n “@timestamp” : {\n “from” : “1572868208628”,\n “to” : “1572871808628”,\n “include_lower” : true,\n “include_upper” : true,\n “format” : “epoch_millis”,\n “boost” : 1.0\n }\n }\n },\n {\n “query_string” : {\n “query” : "",\n “fields” : [ ],\n “type” : “best_fields”,\n “default_operator” : “or”,\n “max_determinized_states” : 10000,\n “enable_position_increments” : true,\n “fuzziness” : “AUTO”,\n “fuzzy_prefix_length” : 0,\n “fuzzy_max_expansions” : 50,\n “phrase_slop” : 0,\n “analyze_wildcard” : true,\n “escape” : false,\n “auto_generate_synonyms_phrase_query” : true,\n “fuzzy_transpositions” : true,\n “boost” : 1.0\n }\n }\n ],\n “adjust_pure_negative” : true,\n “boost” : 1.0\n }\n}",
“index_uuid”: “kE3y3OR1QZ-Pbr7DYKIdng”,
“index”: “twitter_marvel_elastic_example”
“type”: “search_phase_execution_exception”,
“reason”: “all shards failed”,
“phase”: “query”,
“grouped”: true,
“failed_shards”: [
“shard”: 0,
“index”: “twitter_marvel_elastic_example”,
“node”: “vLhmgrNFSDqITyigl3JhcQ”,
“reason”: {
“reason”: “failed to create query: {\n “bool” : {\n “filter” : [\n {\n “range” : {\n “@timestamp” : {\n “from” : “1572868208628”,\n “to” : “1572871808628”,\n “include_lower” : true,\n “include_upper” : true,\n “format” : “epoch_millis”,\n “boost” : 1.0\n }\n }\n },\n {\n “query_string” : {\n “query” : “",\n “fields” : [ ],\n “type” : “best_fields”,\n “default_operator” : “or”,\n “max_determinized_states” : 10000,\n “enable_position_increments” : true,\n “fuzziness” : “AUTO”,\n “fuzzy_prefix_length” : 0,\n “fuzzy_max_expansions” : 50,\n “phrase_slop” : 0,\n “analyze_wildcard” : true,\n “escape” : false,\n “auto_generate_synonyms_phrase_query” : true,\n “fuzzy_transpositions” : true,\n “boost” : 1.0\n }\n }\n ],\n “adjust_pure_negative” : true,\n “boost” : 1.0\n }\n}",
“caused_by”: {
“type”: “illegal_argument_exception”,
“reason”: “field expansion matches too many fields, limit: 1024, got: 1433”
“status”: 400
“$$config”: {
“method”: “POST”,
“data”: “{“search_type”:“query_then_fetch”,“ignore_unavailable”:true,“index”:“twitter_marvel_elastic_example”}\n{“size”:0,“query”:{“bool”:{“filter”:[{“range”:{”@timestamp":{“gte”:“1572868208628”,“lte”:“1572871808628”,“format”:“epoch_millis”}}},{“query_string”:{“analyze_wildcard”:true,“query”:"”}}]}},“aggs”:{“2”:{“date_histogram”:{“interval”:“5s”,“field”:”@timestamp",“min_doc_count”:0,“extended_bounds”:{“min”:“1572868208628”,“max”:“1572871808628”},“format”:“epoch_millis”},“aggs”:{}}}}\n"
