IIS Timestamp Format
Hi All,
Anyone tried converting IIS logs which is in UTC to ET to match the Grafana loki Ingester timestamp? I don’t want to change the IIS logs timestamp rather I would like to handle it in Grafana agent config.
I don’t think you need to match your logs to ingester’s timestamp. Also unless there is a good reason i’d keep the ingester in UTC, too.
Hi Tony,
Most of our application logs are in ET timezone. Only IIS, event viewer logs are in UTC. We would need to convert this to ET so that we can avoid duplicate logs pushing to loki.
