I want to club 4 different dashboards into one dashboard and filter the Row options A, B, C, D
I want to club 4 different dashboards into one dashboard and filter the Row options A, B, C, D.
Every dashboard (A,B,C,D) has 9 metrics with Row option creation with Title like CPU, Heap, WebServices etc.,
On top of A B C D dashboard i need to create filter.
whenever i want to select A dashboard then that dashboard only have to be visible.
Example like as below link it has Interface filter.
Please let me know if i need clarify more on this. Thanks in advance.,
Regards,
Srikanth.
hello the link is not working please show image
If your A, B, C, D are input variables for the panels then only it works. And all the rows will have the same KPIs.
