I need a dashboard case for load balancing
Who has a dashboard for load balancing (SLB),There is no SLB dashboard on the website
Ask for help. Thank you
I suggest adding more information about your use case. This will help the community understand your problem and offer advice.
Did you search in…? https://grafana.com/grafana/dashboards
Yes, I have searched and found no related boards of SLB
For SLB monitoring, such as traffic, IP access, and so on, these parameters have a good-looking dashboard to display, just like the host display SLB
