I’m trying use a variable inside a MAX funciont but I Can’t
SELECT
Distance,
MAX(CASE WHEN Driver = 'VER' THEN Speed END) AS Speed_VER,
MAX(CASE WHEN Driver = 'NOR' THEN Speed END) AS Speed_NOR
FROM
telemetria
WHERE
(Lap = $volta AND Country = 'Brazil' AND Driver = $driver01)
GROUP BY
Distance
ORDER BY
Distance;
MAX(CASE WHEN Driver = ${driver01:singlequote} THEN Speed END) AS Speed_VER,
MAX(CASE WHEN Driver = ${driver02:singlequote} THEN Speed END) AS Speed_NOR
but then your query wont make sense as the where clause uses
I’m trying to make dynamic panels in Grafana from CSV files but I can’t link variables to the panel. Do you know if with CSV files you can’t use variables?
