Grafana is supported by Clickhouse, which Hydrolix uses as its front end. Has anyone used Grafana as the front end for CDN observability to stop shipping logs to Splunk? Feels like it would be cheaper and more flexible to use Grafana.
If you are interested in a log management solution, then give Loki at try
Good Luck
Hello @jwp406323. We just posted a walkthrough for visualizing Fastly CDN logs using Grafana on Hydrolix. If you are interested, here’s the post:
Visualizing Fastly data with Hydrolix and Grafana
Please let me know if you have any additional questions.
Tobin(Hydrolix)
