As of recent we have upgraded Grafana from 7.3 to 7.5.4. We’ve noticed that in 7.5 and onwards (maybe even in 7.4, but we couldn’t check) images using a href link are no longer fully clickable, but are now only clickable in a very small area in the center of the image.
This was not present in 7.3, where images with hrefs were fully clickable.
Example of our visual:
Text visual with the following HTML: <center><a href="dashboard_link"><img src=image_link.png width=75%></a></center>
Things we’ve tried with no success:
Remove the tags
Remove the ‘width=75%’ restraint
Is this a 7.4/5 related issue? Any tips on how to fix this or create a workaround is very much appreciated!
The reason why my original request was closed was because it was not a bug, it was actually by design. Apparently, you need to add style=“display: block;” into your HTML a line. This was not necessary in 7.3.
Thank you, but it’s still not described anywhere and not expected by users.
I just updated stylesheets for my plugins and it works perfectly.
Closed the issue.
