7.5.10 -
I want to see the HTTP Dashboard API calls that are being made to the Grafana instance from the Grafana UI so that I can better understand how the API works. I want to automate the saving and restoring of dashboards using CICD pipelines. In other words, I’d like to see a log of all the API calls that are being sent to the Grafana instance so I can understand how the UI itself is getting things done. Hopefully this is a matter of modifying the log level?
The HTTP Dashboard API documentation seems very limited. For example I want to be able to retrieve a dashboard using the NAME of the dashboard, but it looks like the Dashboard API only allows you to specify the UIDs. Since the Grafana is using the HTTP API, I’d like to see how the UI is making these calls so I can do the same thing, but through my CICD process.
Being able to see these API calls and how the Grafana UI calls them will help me better understand the APIs in general because the docs don’t seem to provide very meaningful examples (at least, to me).
Don’t know how yet. -
What happened?
N/A -
N/A -
N/A currently. -
N/A -
Dashboard HTTP API | Grafana Labs
