Hi, all
I am wondering how to use “Value groups/tags” to filter muti-value hosts and list the tag aside? I am using zabbix as datasource and I want it to be supported. Could anyone help me with this? Thanks.
Take a look at example dashboard with tags
http://play.grafana-zabbix.org/dashboard/db/templating-guide-advanced?orgId=2
hi, I’m having the same problem, did you get to find your answer?
hi, i’m having the same problem. Has anyone solved it?
Nop. I’m trying tho. The link @alexanderzobnin provided did’nt help either because it is pointing me to a page saying “Not Possible to Load”… I even opened myself a question about this since this one did’nt had any solutions, so far.
