How to use Log Values for a Data Link
Hi, I like to create a Data Link within my log panel to jump from a Log-Entry (json-format) to the trace and the spans. The log is parsed correctly, and the traceid is key/value pair. But how to use it correctly in a data link?
[EDIT]
I have figured out, I have to transform the logs into a table visualization, and then I can use data links. Is there any way to do that in the logs panel?
